Ruslan Manianov
Aug 8, 2022 11:03 AM UTC
Getting bitmap from TextArea. Is it posible?
Hello. I create pdf files on my STM32 and save they to usb flash. And i want to add to files strings as images. So is it possible to render textArea to bytes array as bitmap?
Yoann KLEIN
Aug 8, 2022 1:03 PM UTC
Hello @Ruslan Manianov​ ,
Sorry, I'm not sure to understand exactly what you want to do here. Are you trying to display pdf on the board ? Could you elaborate please ?
Thank you,
/Yoann
Yoann KLEINST Software Developer | TouchGFX
Ruslan Manianov
Aug 8, 2022 1:54 PM UTC
No, I generate pdf file on STM32 and want to add textArea from screen to it as image. Because if add textArea as text, we need to embed the using font to pdf file. But i can't find library for pdf that can embed fonts. So more easy and faster is add texts as image because i have all needed texts on screen and i know how to do that. I try make snapshot by snapshot widget but i get error with it and i can't finde example how use this widget to resolve this error. Also this method returns text with background from screen, but i need text on white bg. So the best variant i see is rendering textArea to bytes array as image and adding this array to pdf file. I hope I could describe my question. Thanks.
