CCao.1
Apr 21, 2021 4:08 AM UTC
generated/simulator/gcc/Makefile:149: recipe for target 'generate_assets' failed
I followed the steps to run the simulator on PC using the demo from touchgfx,it pops out this error. no idea why it turns to so strange include path. On my PC I installed QNX650 EDA, Visual Studio. No idea how I can fix this.
 Compile
    make -f simulator/gcc/Makefile -j8
    Reading ./application.config
    /usr/bin/sh: C:TouchGFX4.16.0envMinGWmsys1.0QNX650targetqnx6usrinclude: command not found
Romain DIELEMAN
Apr 21, 2021 7:01 AM UTC
Are you able to generate code or run the simulator from TouchGFX Designer ? Or do you also face this issue ?
What is the path of your project (is there any space in the name of one of the folder, or an "unusual" character ?)
Are you on a project created from scratch or have you used an application template available in TouchGFX Designer for one of the ST development boards ?
/Romain
Pavel A.
Apr 21, 2021 7:26 AM UTC
QNX IDE was known for adding its make.exe to PATH. Don't know about the current version.
Sanitize your environment, especially PATH.
--pa
Krautermann
Senior
Apr 26, 2023 7:17 AM UTC
I am having this problem, has anyone found a solution to this?
Pavel A.
Apr 26, 2023 1:14 PM UTC
Same question, same answer. You probably have QNX IDE installed. Remove its environment variables from PATH and environment. especially MAKE, LIB, INC and so on.
Krautermann
Senior
Apr 26, 2023 1:19 PM UTC
@pavel A.​ Actually not! I have only STM32Cube IDE installed. No other IDE exist!
