MMAUR.1
Generated code failed in toughGFX +CubeMX
I'm using STM32f429ZI Discovery board to run the touch LCD using LTDC
I will attach Detatiled Log.
Thank you.
error1: in touchGFX while generating a code
Generate Code
  Copy Framework
    Copying TouchGFX framework version 4.14.0 to E:\touchgfx_lcd\lcd2\Middlewares\ST\touchgfx
    Done
  Generate
    Wrote config/gcc/app.mk
    Wrote config/msvs/Application.props
    Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
    Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
    Wrote generated/gui_generated/include/gui_generated/screen_screen/screenViewBase.hpp
    Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
    Wrote generated/gui_generated/src/screen_screen/screenViewBase.cpp
    Wrote generated/simulator/gcc/Makefile
    Wrote generated/simulator/include/simulator/mainBase.hpp
    Wrote generated/simulator/msvs/touchgfx.props
    Wrote generated/simulator/msvs/touchgfx_prebuild.targets
    Wrote generated/simulator/msvs/touchgfx_sdl2.props
    Wrote generated/simulator/src/mainBase.cpp
    Wrote generated/simulator/touchgfx.ico
    Wrote generated/simulator/touchgfx.rc
    Wrote generated/simulator/touchgfx.res
    Wrote gui/include/gui/common/FrontendApplication.hpp
    Wrote gui/include/gui/common/FrontendHeap.hpp
    Wrote gui/include/gui/model/Model.hpp
    Wrote gui/include/gui/model/ModelListener.hpp
    Wrote gui/include/gui/screen_screen/screenPresenter.hpp
    Wrote gui/include/gui/screen_screen/screenView.hpp
    Wrote gui/src/common/FrontendApplication.cpp
    Wrote gui/src/model/Model.cpp
    Wrote gui/src/screen_screen/screenPresenter.cpp
    Wrote gui/src/screen_screen/screenView.cpp
    Wrote simulator/gcc/Makefile
    Wrote simulator/main.cpp
    Wrote simulator/msvs/Application.sln
    Wrote simulator/msvs/Application.vcxproj
    Wrote simulator/msvs/Application.vcxproj.filters
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Reading ./application.config
    Generating generated/images/include/BitmapDatabase.hpp
    Generating generated/images/src/BitmapDatabase.cpp
    Cleaning generated files from generated/texts and generated/fonts.
    Generating generated/fonts/src/GeneratedFont.cpp
    Generating generated/fonts/include/fonts/GeneratedFont.hpp
    Generating generated/fonts/include/fonts/CachedFont.hpp
    Generating generated/fonts/src/CachedFont.cpp
    Generating generated/fonts/include/fonts/FontCache.hpp
    Generating generated/fonts/src/FontCache.cpp
    Generating generated/fonts/src/ApplicationFontProvider.cpp
    Generating generated/fonts/include/fonts/ApplicationFontProvider.hpp
    Generating generated/texts/include/texts/TextKeysAndLanguages.hpp
    Generating generated/texts/include/texts/TypedTextDatabase.hpp
    Generating generated/texts/src/TypedTextDatabase.cpp
    Generating generated/texts/src/Texts.cpp
    Done
  Post Generate
    touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
    Done
  Post Generate Target
    touchgfx update_project --project-file=../touchgfx.ioc --platform=m4
    Unable to locate E:/touchgfx_lcd/lcd2/touchgfx.ioc
    Failed
  Failed
error2: Cube MX while compiling the code
../Core/Src/main.c:24:10: fatal error: app_x-cube-touchgfx.h: No such file or directory
 #include "app_x-cube-touchgfx.h"
compilation terminated.
make: *** [Core/Src/subdir.mk:41: Core/Src/main.o] Error 1
make: *** Waiting for unfinished jobs....
"make -j8 all" terminated with exit code 2. Build might be incomplete.
Alexandre RENOUX
October 14, 2020
Could you provide the steps you did until the build errors ?
What is app_x-cube-touchgfx.h ? This is not something from our projects. Have you used the F429-DISCO Application template available in TouchGFX Designer ?
/Alexandre
