VKost.3
Function animateToItem makes a two animationSteps and HardFault
I am using stm32f746 nucleo board and display with fmc!
his is how it works
void Screen1View::handleTickEvent()
tickCounter++;
if(tickCounter > 60){
tickCounter = 0;
scrollWheel.animateToItem(scrollWheel.getSelectedItem() + 1, 0);
// application().gotoScreen2ScreenSlideTransitionEast();
doesn't work like that! Makes a two animationSteps and HardFault!
tickCounter++;
tickCounter = 0;
scrollWheel.animateToItem(scrollWheel.getSelectedItem() + 1, 10);
VKost.3
VKost.3Author
tickCounter++;
tickCounter = 0;
MM..1
??? why you duplicate
??? why you dont check index over limit, you cant animate to not existed +1 on last.
VKost.3
VKost.3Author
I gave this two options. The first one without steps, the second with steps! The first option works fine without overflow checking. I gave this two options. The first one without steps, the second with steps! The first option works fine without overflow checking. The second option with steps, redraws the first two frames and gets into HardFault!
VKost.3
VKost.3Author
Changed the location of the buffers, from by location to by address! and it all worked)
