Refused_HC
Mar 9, 2026 10:46 AM UTC
FreeRTOS task execution frequency changes with TouchGFX screen
Hello community,
I have this problem. I have a project with the STM32U575RGTx microcontroller.
It includes also FreeRTOS (Version 1.3.1) and a TouchGFX project (Version 4.26.0).
With this system configuration: Timebase Source TIM17
The TouchGFX project has screens that require more or less CPU, the problem that I have is that when one or other screen is selected the execution frequency of the FreeRTOS tasks and the HAL_TIM_PeriodElapsedCallback change their execution frequency, so I can not have a valid time reference to do other things in my firmware application.
Has anyone faced the same problem?
Much thanks in advance!
Osman SOYKURT
Osman SOYKURTBest answer
Mar 26, 2026 2:55 PM UTC
Hello @Refused_HC ,
I think your configuration is wrong, first of all I see 15 as priority for your TIM17 which is the lowest priority, I think his needs to be higher like 4 (the lowest you set it, the highest is the priority).
I also invite you to look again at your TouchGFX thread config in your FreeRTOS config. We have a guide explaining how to set FreeRTOS properly, I strongly recommend you to check it if you've not already. If it still doesn't work after that, we'll check it together again :)
Osman SOYKURT
Mar 16, 2026 4:01 PM UTC
Hello @Refused_HC
Could you send me your ioc file? (You can send me via private message if you prefer)
Refused_HC
Mar 17, 2026 7:01 AM UTC
Here it is @Osman SOYKURT and thanks in advance!
Osman SOYKURT
Hello @Refused_HC ,
Osman SOYKURT
Apr 7, 2026 11:58 AM UTC
Hello @Refused_HC ,
Did you manage to resolve your issue?
