Eiffel
Feb 26, 2023 9:55 PM UTC
FreeMarker template error
Hello all,
ST is obviously ignoring problems because i have found few topics about this issue which are two years old. So, during TouchGfx generation from CubeMX i get an errors in TouchGFXGeneratedHAL.cpp
Java has obviously still have problems with big numbers and ST is still unable to fix it. Know anybody walkaround?
Osman SOYKURT
Feb 27, 2023 10:40 AM UTC
Hello MPetr.5,
We're sorry if you think we're ignoring it, we try to constantly upgrade TouchGFX Designer with resolving issues and adding new features for an optimal user experience. It's possible that the issue you're referring hasn't been prioritized. Could you send me the link to the other topics you mentioned?
Also, more details would be appreciated for a deeper look by us; which board are you using? is it based on a TouchGFX board setup? which version of TouchGFX and STM32CubeMX?
/Osman
Eiffel
EiffelAuthor
Feb 28, 2023 5:42 PM UTC
Hello @Osman SOYKURT​ ,
https://community.st.com/s/question/0D53W00001Az0B6SAJ/error-in-code-generation-for-touchgfx
https://community.st.com/s/question/0D53W00000yVf83SAC/bug-on-cubemx-touchgfx
Those are 2years old.
No board, custom PCB with STM32L4R9ZG, LCD connected through FMC bank 2, on bank1 is SRAM.
STM32CubeMX version 6.7.0
TouchGFX 4.21.1
It is obviously problem with high address which exceedes 32bit value and freemarker/java cannot handle it.
Pavel A.
Mar 3, 2023 2:12 PM UTC
Does unsigned int give any hint?
https://stackoverflow.com/questions/9854166/declaring-an-unsigned-int-in-java
Eiffel
EiffelAuthor
Mar 5, 2023 6:58 PM UTC
Hi, i dont know who are you targeting. Maybe ST?
