VLau
Forbit clicks outside window
I need ModalWindow functionality where clicks outside it are forbidden. In my case my window is a container, how can I prevent clicks outside it?
Seems easy but doesn't work for me. I tried make empty boxes and empty containers size of screen and set them untouchable and visible. However I still can click content under them.
Michael K
Michael KBest answer
Senior III
December 7, 2021
Yup, if you wanted to do this in the designer you can create the empty container and add a ClickListener mixin to it.
Embedded UI/UX Consulting: cadenza.design
VLau
VLauAuthor
Ok, solved it. Needed to set empty container touchable instead of untouchable. In this case clicks go to that empty container which covers Screen content.
Michael K
Senior III
December 7, 2021
