ananya
Dec 31, 2019 6:33 AM UTC
font files and its memory requirement.
While using touchGFX, which font files should be used for the following languages
1.German,
2.english,
3.french,
4.spanish,
5.italian,
6.portuguese,
7.swedish,
8.russian,
9.czesh,
10.polish,
11.chinese,
12.japanese,
13.korean,
14.turkish
For each font file what would be the memory required?
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Jan 8, 2020 12:22 PM UTC
I can't answer that. It's up to you which font you want to use - You need to investigate if that font has the unicodes that suit your needs for some language. Memory requirements (flash) depend on the size defined by the typography you define in TouchGFX and the quality of the font.
/Martin
Martin KJELDSEN
Principal III
/Martin
