FFC cable and connector compatible with DCMI interface of H747I-DISCO board
I want to design a small interface board connecting to the camera interface of the H747 DISCO board through a flat flexible cable.
Will AFC07-S30ECA be compatible ?
Can you recommend a flat cable and its part number ?
Thanks,
Christian
CIsel.1Author
answering myself... in case anyone else wonders - yes it works, and I'm using https://www.we-online.de/katalog/datasheet/687630050002.pdf as cable
board design is here https://oshwlab.com/ciseli/ffc_interface
use example is here https://github.com/c4chris/H747-WeighingStation
