Oct 8, 2026 9:25 AM UTC
Feature request: lock/unlock all selected items in Designer
Current TouchGFX version used: 4.26.0
It would save some time if it was possible to lock/unlock all currently selected items in TouchGFX Designer via the right-click context menu:
As an additional request it would also be of great use if you could Shift-select a bunch of elements in one go. Currently, you can only use Ctrl+Click to select multiple elements as in the above image. However, it would be useful to also have a Shift+Click for below usecase:
Osman SOYKURT
Osman SOYKURTBest answer
Oct 8, 2026 11:43 AM UTC
Hello ​@Aron Hoogeveen ,
You’re right I also believe this would save some time, I appreciate the suggestion. I’ll talk about it to the team 👍
Osman SOYKURT
