P F
Dec 24, 2017 7:43 PM UTC
[F4]Using FSMC and FMC together
Posted on December 24, 2017 at 20:43
is it possible to use the FSMC (LCD 8080) and the FMC (SDRAM) together on an STM32F4?
I want to drive an SDRAM and an LCD on the same address and data lines. Will there be any problems with this setup?
#lcd #stm32f4-fmc #sdram #fsmc
Tesla DeLoreanBest answer
Dec 24, 2017 9:54 PM UTC
Posted on December 24, 2017 at 22:54
Review example code for 439 EVAL board, pretty sure that mixes SDRAM, SRAM, NOR, etc
http://www.st.com/en/evaluation-tools/stm32439i-eval.html
P F
P FAuthor
Dec 25, 2017 12:44 PM UTC
Posted on December 25, 2017 at 12:44
Yes, you re right. The eval board mixes SDRAM and SRAM. I also found an example in the SPL how to use both (SDRAM must be put into idle to use SRAM).
