Roger.ch
Sep 21, 2023 1:05 PM UTC
Example of a ClickListener?
How does this work with a ClickListener?
I have a view with 10 custom containers. How can I tell the view when a custom container has been pressed and which one? Do you have a simple example?
Regards, Roger
FBLBest answer
Sep 21, 2023 1:45 PM UTC
Hello @Roger.ch
Did you check this? Mixins | TouchGFX Documentation
You can find examples of implementation in Demos
FBLBest answer
Hello @Roger.ch
Roger.ch
Roger.chAuthor
Sep 21, 2023 4:20 PM UTC
Hi F.Belaid
Thank you very much for your tip. Unfortunately I had not found the example. But it looks good.
I will have a look at it tomorrow.
Best regards, Roger
