Error while renaming the touch gfx project
- 2 replies
- 717 views
Hello All,
I need to change the touch GFX project name MyApplication_747I to something else, I am trying to change it from config but touch gfx is not allowing it to change.
I tried to edit and modify the .touchgfx file and changed the name from "Name": "MyApplication_747I ", to "Name": "UI_Software", along with "ProjectFile": "../../STM32H747I-EVAL.ioc", to "ProjectFile": "../../IPL_UI_Software.ioc",
Additionally I have changed file ApplicationTemplate.touchgfx.part in this "Name": "IPL_UI_Software", and "ProjectFile": "../../IPL_UI_Software.ioc",
While loading the file and opening the touchgfx project using the .touchgfx project I am getting attached Error.
Could you please suggest what further modification i need to make or any corrections to do so that i can change the desire name of project safely.
Attached are the logs for your reference to get better clarity.
BR,
Shiv
