Nov 21, 2023 2:18 PM UTC
DynamicGraph issues
I've been using dynamicGraph regularly by now (mostly in TouchGFX) and, randomly, in the generated code of both the .hpp and .cpp files (mainPageViewBase.hpp/.cpp) istances of elements inside the dynamicGraph are deleted/not generated (GraphelementDots and GraphElementHistogram classes).
This causes build to fail.
Simply deleting and recreating elements inside dynamicGraph (in TouchGFX) "fixes" the issue (build is successful), but the problem occurs regularly almost every time I build the code, so it is not a practical and definitive solution.
Do you think it's a touchGFX bug?
Here's what console is reporting while trying to build the code:
In file included from ../TouchGFX/gui/include/gui/mainpage_screen/mainPageView.hpp:4,
 from ../TouchGFX/gui/src/mainpage_screen/mainPageView.cpp:1:
../TouchGFX/generated/gui_generated/include/gui_generated/mainpage_screen/mainPageViewBase.hpp:167:15: error: using-declaration for non-member at class scope
 167 | touchgfx::GraphElementHistogram ;
../TouchGFX/generated/gui_generated/include/gui_generated/mainpage_screen/mainPageViewBase.hpp:168:15: error: using-declaration for non-member at class scope
 168 | touchgfx::GraphElementDots ;
 from ../TouchGFX/gui/src/mainpage_screen/mainPagePresenter.cpp:1:
arm-none-eabi-g++ "../TouchGFX/generated/gui_generated/src/containers/menuTopbarBase.cpp" -mcpu=cortex-m33 -std=gnu++14 -g3 -DDEBUG -DFX_INCLUDE_USER_DEFINE_FILE -DLX_INCLUDE_USER_DEFINE_FILE -DTX_INCLUDE_USER_DEFINE_FILE -DTX_SINGLE_MODE_NON_SECURE=1 -DUX_INCLUDE_USER_DEFINE_FILE -DUSE_HAL_DRIVER -DSTM32U599xx -c -I../Core/Inc -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/ts3510" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/Common" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/rtc_rv3028c7" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/zmod4410" -I../FileX/App -I../LevelX/App -I../TouchGFX/App -I../TouchGFX/target/generated -I../TouchGFX/target -I../AZURE_RTOS/App -I../USBX/App -I../USBX/Target -I../Drivers/STM32U5xx_HAL_Driver/Inc -I../Drivers/STM32U5xx_HAL_Driver/Inc/Legacy -I../Middlewares/ST/levelx/common/inc -I../Middlewares/ST/threadx/common/inc -I../Drivers/CMSIS/Device/ST/STM32U5xx/Include -I../Middlewares/ST/filex/common/inc -I../Middlewares/ST/filex/ports/generic/inc -I../Middlewares/ST/threadx/ports/cortex_m33/gnu/inc -I../Middlewares/ST/usbx/common/core/inc -I../Middlewares/ST/usbx/ports/generic/inc -I../Drivers/CMSIS/Include -I../Middlewares/ST/touchgfx/framework/include -I../TouchGFX/generated/fonts/include -I../TouchGFX/generated/gui_generated/include -I../TouchGFX/generated/images/include -I../TouchGFX/generated/texts/include -I../TouchGFX/generated/videos/include -I../TouchGFX/gui/include -I../Middlewares/ST/usbx/common/usbx_stm32_host_controllers -I../Middlewares/ST/usbx/common/usbx_host_classes/inc -I../Drivers/BSP/Components/is25lp032d -I../FileX/Target -I../Middlewares/ST/touchgfx_components/gpu2d/NemaGFX/include -I../Middlewares/ST/touchgfx_components/gpu2d/TouchGFXNema/include -O0 -ffunction-sections -fdata-sections -fno-exceptions -fno-rtti -fno-use-cxa-atexit -Wall -femit-class-debug-always -fstack-usage -fcyclomatic-complexity -MMD -MP -MF"TouchGFX/generated/gui_generated/src/containers/menuTopbarBase.d" -MT"TouchGFX/generated/gui_generated/src/containers/menuTopbarBase.o" --specs=nano.specs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -o "TouchGFX/generated/gui_generated/src/containers/menuTopbarBase.o"
arm-none-eabi-g++ "../TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.cpp" -mcpu=cortex-m33 -std=gnu++14 -g3 -DDEBUG -DFX_INCLUDE_USER_DEFINE_FILE -DLX_INCLUDE_USER_DEFINE_FILE -DTX_INCLUDE_USER_DEFINE_FILE -DTX_SINGLE_MODE_NON_SECURE=1 -DUX_INCLUDE_USER_DEFINE_FILE -DUSE_HAL_DRIVER -DSTM32U599xx -c -I../Core/Inc -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/ts3510" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/Common" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/rtc_rv3028c7" -I"D:/APPLICATIVI/TOUCH/HMI4_stmu599_HiDew/Drivers/BSP/Components/zmod4410" -I../FileX/App -I../LevelX/App -I../TouchGFX/App -I../TouchGFX/target/generated -I../TouchGFX/target -I../AZURE_RTOS/App -I../USBX/App -I../USBX/Target -I../Drivers/STM32U5xx_HAL_Driver/Inc -I../Drivers/STM32U5xx_HAL_Driver/Inc/Legacy -I../Middlewares/ST/levelx/common/inc -I../Middlewares/ST/threadx/common/inc -I../Drivers/CMSIS/Device/ST/STM32U5xx/Include -I../Middlewares/ST/filex/common/inc -I../Middlewares/ST/filex/ports/generic/inc -I../Middlewares/ST/threadx/ports/cortex_m33/gnu/inc -I../Middlewares/ST/usbx/common/core/inc -I../Middlewares/ST/usbx/ports/generic/inc -I../Drivers/CMSIS/Include -I../Middlewares/ST/touchgfx/framework/include -I../TouchGFX/generated/fonts/include -I../TouchGFX/generated/gui_generated/include -I../TouchGFX/generated/images/include -I../TouchGFX/generated/texts/include -I../TouchGFX/generated/videos/include -I../TouchGFX/gui/include -I../Middlewares/ST/usbx/common/usbx_stm32_host_controllers -I../Middlewares/ST/usbx/common/usbx_host_classes/inc -I../Drivers/BSP/Components/is25lp032d -I../FileX/Target -I../Middlewares/ST/touchgfx_components/gpu2d/NemaGFX/include -I../Middlewares/ST/touchgfx_components/gpu2d/TouchGFXNema/include -O0 -ffunction-sections -fdata-sections -fno-exceptions -fno-rtti -fno-use-cxa-atexit -Wall -femit-class-debug-always -fstack-usage -fcyclomatic-complexity -MMD -MP -MF"TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.d" -MT"TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.o" --specs=nano.specs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -o "TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.o"
make[1]: *** [TouchGFX/gui/src/mainpage_screen/subdir.mk:22: TouchGFX/gui/src/mainpage_screen/mainPagePresenter.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [TouchGFX/gui/src/mainpage_screen/subdir.mk:22: TouchGFX/gui/src/mainpage_screen/mainPageView.o] Error 1
 from ../TouchGFX/generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp:24,
 from ../TouchGFX/gui/include/gui/common/FrontendHeap.hpp:4,
 from ../TouchGFX/target/generated/TouchGFXGeneratedHAL.cpp:21:
 from ../TouchGFX/target/generated/TouchGFXConfiguration.cpp:21:
make[1]: *** [TouchGFX/target/generated/subdir.mk:35: TouchGFX/target/generated/TouchGFXGeneratedHAL.o] Error 1
make[1]: *** [TouchGFX/target/generated/subdir.mk:35: TouchGFX/target/generated/TouchGFXConfiguration.o] Error 1
In file included from ../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:4:
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp: In constructor 'mainPageViewBase::mainPageViewBase()':
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:238:5: error: expected primary-expression before '.' token
 238 | .setColor(touchgfx::Color::getColorFromRGB(255, 255, 255));
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:239:5: error: expected primary-expression before '.' token
 239 | .setBarWidth(4);
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:240:5: error: expected primary-expression before '.' token
 240 | .setBaseline(0);
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:241:33: error: no matching function for call to 'touchgfx::FadeAnimator<touchgfx::GraphWrapAndClear<25> >::addGraphElement()'
 241 | dynamicGraph.addGraphElement();
In file included from ../Middlewares/ST/touchgfx/framework/include/touchgfx/widgets/graph/GraphWrapAndClear.hpp:22,
 from ../TouchGFX/generated/gui_generated/include/gui_generated/mainpage_screen/mainPageViewBase.hpp:24,
../Middlewares/ST/touchgfx/framework/include/touchgfx/widgets/graph/AbstractDataGraph.hpp:726:10: note: candidate: 'void touchgfx::AbstractDataGraph::addGraphElement(touchgfx::AbstractGraphElement&)'
 726 | void addGraphElement(AbstractGraphElement& d);
../Middlewares/ST/touchgfx/framework/include/touchgfx/widgets/graph/AbstractDataGraph.hpp:726:10: note: candidate expects 1 argument, 0 provided
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:244:5: error: expected primary-expression before '.' token
 244 | .setPainter(Painter);
../TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.cpp:245:5: error: expected primary-expression before '.' token
 245 | .setDotWidth(4);
make[1]: *** [TouchGFX/generated/gui_generated/src/mainpage_screen/subdir.mk:19: TouchGFX/generated/gui_generated/src/mainpage_screen/mainPageViewBase.o] Error 1
 from ../TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.cpp:6:
make[1]: *** [TouchGFX/generated/gui_generated/src/common/subdir.mk:19: TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.o] Error 1
make: *** [makefile:224: all] Error 2
"make -j20 all" terminated with exit code 2. Build might be incomplete.
Nov 23, 2023 10:18 AM UTC
Same problem to me, the software revision of the TouchGFX is 4.22.0.
Waiting for a bug fix of the TouchGFX.
edsattAuthor
Nov 29, 2023 10:31 AM UTC
I'm on the same version, 4.22.0
Feb 1, 2024 3:38 PM UTC
Up
