BGuth.1
Senior
November 15, 2022
Dynamically generate and display QR code
I am using 4.16.1 TouchGFX designer tool. Is it possible to generate QR code for a given string and PIN code in run time and display? Please advice.
MM..1
ktrofimo
Senior III
November 15, 2022
I have used https://github.com/ricmoo/QRCode library.
Made a simple wrapper class QRCode.cpp
#include <gui/widgets/qrcode/QRCode.hpp>
#include <gui/widgets/qrcode/qrcode.h>
#include <stdlib.h>
QR::QR( const char * text )
	 qrcode = new QRCode();
	 qrcodeData = (uint8_t *)malloc( qrcode_getBufferSize(1) );
	 qrcode_initText( qrcode, qrcodeData, 1, 0, text );
QR::~QR()
	free( qrcodeData );
	delete qrcode;
bool QR::at(uint16_t x, uint16_t y) const
 return qrcode_getModule( qrcode, x, y );
uint16_t QR::getWidth() const
 return qrcode->size;
uint16_t QR::getHeight() const
and a custom widget QRCodeWidget.cpp
#include <gui/widgets/qrcode/QRCodeWidget.hpp>
#include <touchgfx/hal/HAL.hpp>
QRCodeWidget::QRCodeWidget() :
 code(0),
 scale(1)
void QRCodeWidget::setQRCode(QR *qrCode)
 code = qrCode;
 updateSize();
void QRCodeWidget::draw(const touchgfx::Rect& invalidatedArea) const
 if(!code)
 return;
 touchgfx::Rect absolute = getAbsoluteRect();
 uint16_t *framebuffer = touchgfx::HAL::getInstance()->lockFrameBuffer();
 for(int y = invalidatedArea.y; y < invalidatedArea.bottom(); y++)
 for(int x = invalidatedArea.x; x < invalidatedArea.right(); x++)
 	int offset=0;
 	switch(touchgfx::HAL::DISPLAY_ROTATION)
 	case touchgfx::rotate0:
 		offset = absolute.x + x + (absolute.y + y) * touchgfx::HAL::DISPLAY_WIDTH;
 		break;
 	case touchgfx::rotate90:
 		offset = (touchgfx::HAL::DISPLAY_WIDTH-(absolute.x + x)-1) * touchgfx::HAL::DISPLAY_HEIGHT
					+ (absolute.y + y);
 		break;
 		framebuffer[offset] = code->at(x / scale, y / scale) ? 0x0000 : 0xffff;
 touchgfx::HAL::getInstance()->unlockFrameBuffer();
touchgfx::Rect QRCodeWidget::getSolidRect() const
 return touchgfx::Rect(0,0,getWidth(), getHeight());
void QRCodeWidget::setScale(uint8_t s)
 scale = s;
 updateSize();
void QRCodeWidget::updateSize()
 if(code)
 setWidth(code->getWidth() * scale);
 setHeight(code->getHeight() * scale);
Using is quite straightforward:
#include <gui/common/QrCodeWidget.hpp>
#include <gui/model/QrCode.hpp>
QRCodeWidget qrCode;
QR *code;
char string[50];
sprintf( string, "http://iwtm.com" );
code = new QR( string );
qrCode.setXY(10,20);
qrCode.setQRCode(code);
qrCode.setScale(8);
add(qrCode);
BGuth.1
BGuth.1Author
Senior
November 15, 2022
Thank you for your reply. I appreciate it. Just so I understand it better, would you mind sharing QrCodeWidget.hpp and QrCode.hpp too please.
ktrofimo
Senior III
November 15, 2022
QRCode.hpp
#ifndef QR_CODE_HPP
#define QR_CODE_HPP
#include <touchgfx/hal/Types.hpp>
#include "qrcode.h"
* @class QRCode
* @brief An interface for getting the value of a qr code at a particular x,y position
* This implementation generates random values for the different x,y coordinates.
* A real qr code will probably save the qr code values in an array like structure and report these instead.
class QR
public:
	QR( const char * text );
	~QR();
 * @fn bool QRCode::at(uint16_t x, uint16_t y);
 * @brief Get the qr code value at a particular coordinate
 * @param x x coordinate
 * @param y y coordinate
 * @return The value of the qr code at the supplied coordinate
 bool at(uint16_t x, uint16_t y) const;
 * @fn uint16_t QRCode::getWidth();
 * @brief Get the width of the qr code
 * @return The width
 uint16_t getWidth() const;
 * @fn uint16_t QRCode::getHeight();
 * @brief Get the height of the qr code
 * @return The height
 uint16_t getHeight() const;
 QRCode *qrcode;
 uint8_t *qrcodeData;
#endif
QRCodeWidget.hpp
#ifndef QR_CODE_WIDGET_HPP
#define QR_CODE_WIDGET_HPP
#include <touchgfx/widgets/Widget.hpp>
#include <gui/model/QRCode.hpp>
* @class QRCodeWidget
* @brief A widget for displaying a QRCode
* The widget will be drawn in black and white.
* The values of the supplied QRCode will determine the appearance
* The widget can be scaled in order to display the qr code in an appropriate size
* @sa touchgfx::Widget
class QRCodeWidget : public touchgfx::Widget
public:
 * @fn QRCodeWidget::QRCodeWidget();
 * @brief Default constructor
 QRCodeWidget();
 * @fn virtual void QRCodeWidget::draw(const touchgfx::Rect& invalidatedArea) const;
 * @brief Draw the part of the qr code that is inside the invalidated area
 * @param invalidatedArea The region of this drawable that needs to be redrawn
 * @sa touchgfx::Drawable
 virtual void draw(const touchgfx::Rect& invalidatedArea) const;
 * @fn virtual touchgfx::Rect QRCodeWidget::getSolidRect() const;
 * @brief Report this widget as being completely solid
 * @return The solid rect.
 virtual touchgfx::Rect getSolidRect() const;
 * @fn void QRCodeWidget::setQRCode(QRCode *code);
 * @brief Set the qr code to display
 void setQRCode(QR *code);
 * @fn void QRCodeWidget::setScale(uint8_t s);
 * @brief Set the scaling factor of the widget
 void setScale(uint8_t s);
private:
 void updateSize();
 QR *code;
 uint8_t scale;
#endif
