Zwei.9
[Dynamic Graph] How to add data points with x value?
I want to draw a graph, and what I expect is that the data points on the left are dense and the data points on the right are sparse. But I only found AbstractDataGraphWithY, a class that ignores x, is there any similar class that does not ignore x can be used.Thank you very much.
