mibra.1
DSI Video Mode Sample for STM32F7 with TouchGFX
Hi ST Team, Current we using an TFT LCD Drv (ST7701) without GRAM. So we have to use DSI in video mode. But it's hard to understand the required DSI video mode configurations. So we need Dsi video mode code working sample.
After Surfing the Stm32 Application notes, we found the following Doc;
  1. dm00287601-dsi-host-on-stm32f469-479-stm32f7x8-x9-and-stm32l4r9-s9-mcus-stmicroelectronics
  2. en.STM32F7_Peripheral_DSIHOST
But it didn't help much. So the DSi sample code will a lot.
October 21, 2020
Aren't there examples related to the STM32F769I-DISCO ?​
mibra.1
mibra.1Author
unfortunately, No.
There is samples for TFT Lcd Drv with Gram. So they are using Command mode.
October 21, 2020
I'm pretty sure that it is using the LTDC/DSI to pump data real time, at pixel clock frequencies
MM..1
I test one demo project 469 simply convert from command mode to video mode . When i rememmber open ioc and change mode setup. Regenerate code and try .
mibra.1
mibra.1Author
Thanks for your help, I wanted to ask if there is sample for dsi video mode with TouchGFX?
mibra.1
mibra.1Author
Hi every one, there is an update, now the lcd is working but the image on the screen is flickering. so. is that timing error?
October 28, 2020
Certainly a lot of interrelationships between various LTDC and DSI clocks, and the screen geometry and colour depth, etc​
October 28, 2020
Watch also that your memory subsystem has enough bandwidth for your resolution and frame rate.
Large resolution and deep colour depth, going to want 32-bit wide SDRAM, clocking optimally.​
