Professional
draw a circle during 100ms on each touch screen press with touchGFX
Do you know if there is a simple way to make touchGFX draw a circle during a few ms on each touch screen press ?
best regards
Martin KJELDSEN
Principal III
August 5, 2019
What do you mean by "during a few ms" ? Are you putting a requirement on the render effeciency of the circle or do you mean that it has to animate from 0 to 100% filled or something like that?
Thanks!
/Martin
Professional
no just print a circle for a few ms (just to tell the user the press has been detected)
Best regards
Martin KJELDSEN
Principal III
August 5, 2019
Ah, you mean show a circle for a few ms then hide it again?
Professional
Yes
Martin KJELDSEN
Principal III
August 5, 2019
The simple thing to do is just to use MyView::handleClickEvent() to show the Circle at the pressed x,y and in the MyView::handleTickEvent() method just keep track of ticks and hide the circle once a certain amount of ticks have passed.
/Martin
Professional
thanks a lot for the help,
now compilation is OK.
But
1) from my function handleClickEvent, how can i get the coordinates (i have to print the circle at the press position...) : call TS_GetState ?
2) i have to implement this functions for all my screens ?
best regards
Professional
Hello
I can't make it work....!!!
here is my implementation :
void DigicodeView::handleClickEvent(const ClickEvent& evt)
 TS_StateTypeDef state;
 touchgfx::Circle circle1;
   touchgfx::PainterRGB888 circle1Painter;
    TS_GetState(&state);
        if (state.touchDetected == 1)
          circle1.setPosition(0, 0, 144, 80);
   circle1.setCenter(52, 41);
   circle1.setRadius(40);
   circle1.setLineWidth(4);
   circle1.setArc(0, 360);
   circle1.setCapPrecision(180);
   circle1Painter.setColor(touchgfx::Color::getColorFrom24BitRGB(199, 16, 16));
   circle1.setPainter(circle1Painter);
circle1.setVisible(true);
circle1.invalidate();
best regards
Martin KJELDSEN
Principal III
August 6, 2019
No, you don't have to call TS_GetState. This is already called in the TouchController implementation. Notice the arguments to handleClickEvent. You can get x and y from
evt.getX()
evt.getY()
/Martin
Professional
Hello
thank you for your reply
I still can't make it work : the circle doesn't appear; do you have any idea why ?
In the setup screen i add a circle :
void DigicodeView::setupScreen()
   DigicodeViewBase::setupScreen();
   circle1.setPosition(0, 0, 480, 272);
   circle1.setCenter(x,y);
   add(circle1);
   circle1.setVisible(false);
In the handleClickEvent i try to show the circle
  int16_t x = evt.getX();
  int16_t y = evt.getY();
best regards
Martin KJELDSEN
Principal III
August 6, 2019
You need to add() the circle to the root container. Did you remember to do that? Just add all your circles in setupScreen() (even if they are invisible).
/Martin
