Yoann KLEIN
Yoann KLEINBest answer
Feb 17, 2023 1:07 PM UTC
Could you try to download that zip folder.
Then copy it inside the C:\Users\USERNAME\AppData\Roaming\TouchGFX-4.21.1\Downloads\STM32H7B3I-DK\3.0.12 folder and replace its extension with ".tpa".
Then open TouchGFXDesigner again and let me know if it works.
/Yoann
Yoann KLEINST Software Developer | TouchGFX
Yoann KLEIN
Feb 17, 2023 8:48 AM UTC
Hello @stefanHriellström​,
I just succeeded to download it on my computer, with the same version.
Did you check your internet connection ? If you don't have internet, or if TouchGFXDesigner cannot access to the server to download the TouchGFX Board setups, a red warning triangle should appear on the top left corner of the home screen.
/Yoann
KDJEM.1
Feb 17, 2023 8:49 AM UTC
Hello @stefanHriellström​ and welcome to STCommunity :) ,
I have checked from my side and I cannot reproduce this issue.
I recommend you to follow properly the steps as described in this MOOC.
Also, I advise you to take a look at this article.
I hope this help you!
Kaouthar
SHell.3
SHell.3Author
Feb 17, 2023 9:01 AM UTC
Very strange!
Other tested board setups was OK to download.
STM32H7B3I DK >> Download of STM32H7B3I DK failed
STM32H7B3I Evulation >> Download 100%, OK
Internet is OK!
Yoann KLEIN
Feb 17, 2023 9:07 AM UTC
Can you provide screenshots please ? And also share the .log file located at C:\Users\USERNAME\AppData\Roaming\TouchGFX-4.21.1\TouchGFXDesigner.log.
Thanks,
/Yoann
SHell.3
SHell.3Author
Feb 17, 2023 9:38 AM UTC
Here comes 2 log files and one screenshot
/Stefan
Yoann KLEIN
Feb 17, 2023 9:57 AM UTC
Can you please try to create a project with STM32F746G-DISCO ? And let me know how it goes.
/Yoann
SHell.3
SHell.3Author
Feb 17, 2023 10:03 AM UTC
It went well to create a project with STM32F746G-DISCO
/Stefan
Yoann KLEIN
Feb 17, 2023 10:17 AM UTC
Then close TouchGFXDesigner, go to "C:\Users\USERNAME\AppData\Roaming", and delete the TouchGFX-4.21.1 folder. After that open TouchGFXDesigner 4.21.1 again, wait 1-2 minutes and try again with H7B3-DK.
