VLesc.1
DMA2D throws configuration error
Hello!
We are use STM32H747 and TouchGFX. We are need to use DMA2D. But we have issue with mode DMA2D_R2M.
Our configuration
 hdma2d.Instance = DMA2D;
 hdma2d.Init.Mode = DMA2D_R2M;
 hdma2d.Init.ColorMode = DMA2D_OUTPUT_ARGB8888;
 hdma2d.Init.OutputOffset = 0;
 if (HAL_DMA2D_Init(&hdma2d) != HAL_OK)
 while (1);
 if (HAL_DMA2D_ConfigLayer(&hdma2d, 1) != HAL_OK)
 while (1);
Our test
NVIC_EnableIRQ(DMA2D_IRQn);
HAL_DMA2D_Start_IT(&hdma2d, 0x12345678, 0xD0165800, 640, 572);
In this case we have callback from DMA with configuration error.
For mode DMA2D_R2M - all Ok.
Any ideas?
VLesc.1
VLesc.1Best answer
Thanks for answer!
But I found that for hdma2d.Init.Mode = DMA2D_R2M function HAL_DMA2D_Init (...) set into CR mode as 0x07, not 0x03.
I updated code for correct mode and now all works!
Hello @Community member​ ,
Have a look at the "Configuration error detection" subchapter of DMA2D chapter in the RM0399, and check with the condition and configuration that you have.
Hope this helps you :smiling_face_with_smiling_eyes: !
Please mark my answer as best by clicking on the "Select as Best" button if it helped.
Imen
VLesc.1
VLesc.1AuthorBest answer
Thanks for answer!
Thanks for sharing the update and your solution!
I'm really glad to know you overcame this problem :)
Imen
