Marco.D
DMA2D for A4 Color mode
Hi, I am developing code for a display on the STM32746G-Discovery.
Is it possible to display fonts without blending? (Not to have to erase the background beforehand)
If I use the DMA2D with memory to memory with blending, everything works as expected, However if I just use the Memory to Memory with PFC I am getting a filled rectangle.
It is like I can't pass information about the background colour; I understand the background fifo is not activated. Is it not possible because of that?
Despair1337
Do you have combine alpha and input alpha set to your color?
Marco.D
Marco.DAuthor
Hi MKraus,
at th ened I gave up, I am erasing the whole screen and then drawing again everything.
I have an RGB565 layer, so there is no alpha channel there.
