KMili
Oct 7, 2019 11:51 AM UTC
Discard GestureEvent on Slider
I have a slider added on View. Also, my view overriders handleGestureEvent to handle it globally. Do you have any idea how to discard gesture event, when I quickly move slider?
Same problem when My FrontendApplication overrides handleGestureEvent.
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Oct 7, 2019 1:45 PM UTC
 * @fn virtual void Drawable::handleDragEvent(const DragEvent& evt)
 * @brief Defines the event handler interface for DragEvents.
 * Defines the event handler interface for DragEvents. The event is only received if
 * the drawable is touchable.
 * @param evt The DragEvent received from the HAL.
 virtual void handleDragEvent(const DragEvent& evt) { }
Concretely, in your view (having declared handleDragEvent() in MyView.hpp) - Something like this:
void MyView::handleDragEvent(const DragEvent& evt)
 drag_x = evt.getDeltaX();
 if(drag_x < drag_threshhold)
 View::handleDragEvent(evt);
/Martin
Martin KJELDSEN
Principal III
Oct 7, 2019 1:40 PM UTC
Hi @KMili​,
If you override your handleDragEvent() method in the view you can see the delta moved between ticks. If that delta is sufficiently large, the drag must've been quite fast - Then do not forward it to the slider.
/Martin
Martin KJELDSEN
Principal III
/Martin
