Senior III
May 7, 2025 3:25 PM UTC
DigitalClock position difference between simulator and TouchGFX Designer
I'm using a digital clock in my application but I'm seeing a strange behavior between what I've set into TouchGFX Designer and the simulator
There's no custom code in the application
Why is that? What should I look for?
nico23Author
Senior III
May 8, 2025 6:42 AM UTC
So increasing the size on the bottom part of the box containing the digital clock fixed the cut text
but it's pretty visible that the alignement is completly different between what I'm seeing in the TouchGFX Designer and what it actually renders in the simulator
why is that? Some issue with the font?
May 9, 2025 8:49 AM UTC
Hello @nico23,
Could you send me the font ?
BR,
Louis BOUDOST Software Engineer | TouchGFX
nico23Author
Senior III
May 9, 2025 10:16 AM UTC
Hi @LouisB
I've chosen "Arial" from the Typograhy tab on TouchGFX and set the size to 140.
Here the generated files https://we.tl/t-ZWUMbGXxF4
May 9, 2025 12:17 PM UTC
I dont saw the issue on my side, could you share a project where you have the issue ? Also which version of touch gfx are you on ?
