Kasun Dinesh
Debugging TouchGFX generated project using CubeIDE for STM32F750 board leads to a hardfault
I created a project using touchgfx for H750 board. Then I import it to cubeide and started debugging. When i run it, it stopped inside the hardfault.
I am using Touchgfx 4.13 and cubeide 1.3.1. I can debug (step in to different lines) until i start the RTOS task. Once i run the code after that, it stops on hardfault.
Can someone help me out on this?
Thank you
Martin KJELDSEN
Principal III
June 3, 2020
Hi, when you say "I created a project using touchgfx", do you mean the designer?
/Martin
