Jtron.11
Senior
Mar 20, 2025 5:53 AM UTC
Custom Gauge with Button
Hi all,
Can anyone please give me advice how can I implement a custom Gauge:
That will be used my custom image and needle
That can be also a button, that when I click in the middle of the gauge, the gauge will change image to glowing as it is a button and turn off the gauge glowing as the button off for another click.
Thank you so much.
    Mar 20, 2025 9:50 AM UTC
    Hello @Jtron.11 ,
    There is a gauge widget in TouchGFX that you can use with your custom images.
    For the glowing behavior, you can add a clicklistener to your gauge. Please refer to this tutorial : How to TouchGFX: create a custom clickable area with an invisible widget. Then to be able to change image after the click, you can refer to that post Solved: change image at runtime - STMicroelectronics Community.
    I hope it helps,
    Best regards,
    Louis BOUDOST Software Engineer | TouchGFX
