Bli.11
cubeIDE1.3
Based on STM32H743I EVAL2, cubeIDE1.3 always displays the following when compiling the Touchgfx4.13 code generated by CubeMX5.6:
compilation terminated.
make: *** [TouchGFX/touchgfx/os/subdir.mk:23: TouchGFX/touchgfx/os/OSWrappers_cmsis.o] Error 1
../TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/AbstractPainter.cpp:16:10: fatal error: touchgfx/widgets/canvas/AbstractPainter.hpp: No such file or directory
 #include <touchgfx/widgets/canvas/AbstractPainter.hpp>
make: *** [TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/subdir.mk:132: TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/AbstractPainter.o] Error 1
../TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/AbstractPainterABGR2222.cpp:16:10: fatal error: touchgfx/widgets/canvas/AbstractPainterABGR2222.hpp: No such file or directory
 #include <touchgfx/widgets/canvas/AbstractPainterABGR2222.hpp>
make: *** [TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/subdir.mk:134: TouchGFX/touchgfx/framework/source/touchgfx/widgets/canvas/AbstractPainterABGR2222.o] Error 1
"make -j4 all" terminated with exit code 2. Build might be incomplete.
10:29:07 Build Failed. 9 errors, 0 warnings. (took 48s.93ms)
Martin KJELDSEN
Principal III
March 4, 2020
Did you open the project in the TouchGFX designer and generate code?
/Martin
Bli.11
Bli.11Author
Hi Martin.
Thank you.
That problem has been solved.Causes this condition when the code is not generated again in CubeMX after editing from TouchGFX.
Martin KJELDSEN
Principal III
March 26, 2020
Hi @Bli.1​,
Not sure i completely understand the flow here. Glad it's solved, though.
What are you editing "from TouchGFX" that causes things to fail until you re-generate from CubeMX? I can't think of a scenario where something like this would happen - unless you forgot to generate code from TouchGFX in the first place.
Thanks!
/Martin
Bli.11
Bli.11Author
HI Martin.
Yes, first edit and generate the code in TouchGFX, then go back to CubeMX and generate the code again.
BzLi
Martin KJELDSEN
Principal III
March 27, 2020
And you're saying some things are getting overwritten? TouchGFX Designer will generate some files that are read only and will get overwritten again when you generate code
/Martin
Bli.11
Bli.11Author
I'm sorry,What is the essence, I don't know, but that's the process
BzLi
Bli.11
Bli.11Author
Hi, Martin.
I'm sorry that my English level is too poor. The dialogue between us is based on the translation software.Ask you some more questions about the touch-screen initialization of H743IEVAL2:
I. which pin is connected between MCU and mb1063.schdoc CN3_7pin(INT)? In the application of ToutchGFX: a, how should the CN3_7(INT) pin be initialized in EXIT?B. How should I2C be initialized?
Martin KJELDSEN
Principal III
April 30, 2020
I think you should consult the datasheet to find out how the display is connected, if you haven't found out yet.
