Ezgi
creating application template
I have already a ioc file for my board. So I created an application template for Touchgfx Designer using it. But when I generated the code in Designer, I was getting an error about that ioc file couldn't be found. So I put the ioc file under the project file. Then I got an error about that uvprojx file couldn't be found.
So, what are the needs to create a app template?
Ezgi
EzgiBest answer
Thanks for your answer. I found the problem. When I generate the tpa file, I processed only the TGFX file. I was trying to do something and I forgot that I did. My fault, sorry.
Romain DIELEMAN
From your previous posts I believe you should have done it the "proper" way following the article. So I believe the issue might come from how you configured your project and/or its structure. Could you check in the Designer project, in the "Config" tab, under the "Build" section, what commands you have set ? Could you share your AT or at least a screenshot of your project folder ? Could you also share a screenshot of the errors ?
/Romain
Ezgi
EzgiAuthorBest answer
Romain DIELEMAN
Always good to understand and explain what happened :thumbs_up: Could you select your answer as Best answer ? It might help other users who will face this.
/Romain
