GChen.2
Mar 16, 2020 3:50 AM UTC
created emwin project from cubeMX don't response touchScreen IC
i use cubeMX 5.4 integer emwin graphical middle-ware to test the button widget with touchscreen for the stm32f746g-disco hardware platform, the graph display fine, but the widget does not response the touchscreen. I using the cubeMX 5.4 with FW 1.15 without freeRTOS, compile in keil mdk5.28a.
does anyone have ideal to resolve this problem?
the attached file is the complete project.
