Aug 14, 2026 9:49 AM UTC
Create a curved text or write text at any angle
Hey
I came across this thread: Rotate text at any angle, where @Romain DIELEMAN mentioned a custom widget called TextArc (TextArc.cpp/hpp) demonstrating arbitrary text rotation.
Unfortunately, the original demo files/links seem to be missing or broken. Does anyone still have a copy of this TextArc widget, or can ST re-upload the sample project?
If this demo is no longer available or compatible with recent TouchGFX versions, what is the recommended approach to render/rotate text at arbitrary angles today?
Thanks in advance!
Aug 19, 2026 10:04 AM UTC
I am also looking for this
Aug 20, 2026 8:11 AM UTC
I am not familiar with the custom widget you mention.
But If you just need to rotate the text (not curve), I can suggest that you render your text to a dynamic bitmap using a cacheable container and then show it rotated on the screen using a texture mapper. This solution has been discussed in this thread: Dynamic Bitmap Background Transparency Implementation | Community.
Best regards
Peter
Aug 20, 2026 1:32 PM UTC
Thanks for your advice.
But I was already involved in that thread,and already know this approach.
But this approach  is a bit complicate,If there is a better way, I wont choose to use texture mapper.
Aug 21, 2026 10:57 AM UTC
Ah ok. In think the texture mapper generally is the best approach to show something at “any angle”. Can you elaborate what effect you want to achieve?
