MPast.1
Senior
July 6, 2021
Converting touchgfx designer project
Hi everybodies,
I have just a simple question:
How can I convert a graphic project created with TouchGfx Designer 4.16 into 4.17 version?
I updated the tool in the project. but graphic project is open always with 4.16.
YSN
instead of opening by double-click on the project, you first open 4.17 designer and the go to file open and select you 4.16 project.
it should now ask for migrate to higher version, then it will open from 4.17
