ferro
Lead
Nov 23, 2023 5:48 PM UTC
"const Rect & Drawable::getRect ()" prohibits use as a parameter in e.g. "Screen::invalidateRect ()"
Hi Gfx Team,
Could Drawable::getRect () in Drawable.hpp
const Rect & getRect() const
 return rect;
be changed to
Rect getRect() const
 return rect;
so it can be used as a parameter in e.g.
void Screen::invalidateRect ( Rect & invalidatedArea ) const
 container.invalidateRect ( invalidatedArea );
With the current implementation one has to write
Screen::invalidateRect ( Rect { Drawable::getRect () } );
If not, could you add a variation e.g.
Rect getRectValue() const
 return rect;
Ferro
Feb 6, 2024 3:50 PM UTC
Hello @ferro ,
Thank you for the good suggestion. I think it would be easier if you use Drawable.invalidateRect() to avoid dealing with coordination conversion (for instance, from local to global).
But, anyway, you can easily copy Drawable.hpp to your project and apply changes to it. For example, you can overload the invalidateRect() like this:
void invalidateRect (const Rect& invalidatedArea) const
 Rect r = invalidatedArea;
 invalidateRect(r);
You can read more about apply changes to widgets here
I hope this helps you,
Best regards
Mohammad MORADIST Software Developer | TouchGFX
Hello @ferro ,
 invalidateRect(r);
Best regards
