Jul 4, 2024 8:30 AM UTC
Compile Error
Greetings,
I just migrated the latest TouchGFX version (4.24.0) and now I am getting a compile error:
[build] ...../touchgfx_win/generated/simulator/src/mainBase.cpp:39:10: error: 'lcd' is not a member of 'HAL'; did you mean 'lcd'?
You have to change
HAL::lcd().setVectorFontRenderer(&vectorFontRendererImpl);
to
touchgfx::HAL::lcd().setVectorFontRenderer(&vectorFontRendererImpl);
In to get rid of the compile error. Any chances to fix this issue?
Jul 4, 2024 8:50 AM UTC
FYI: I have a work-arround where I just copied the content into the upper layer which calls the function "
setupSimulator" and removed the file from our build.
