KNara.2
Jul 5, 2023 11:24 AM UTC
Communication from screen to backend
I'm trying to send an event when a button is clicked.
I have added an interaction in Touchgfx designer to call a virtual function when the button is clicked.
In Screen1view.cpp I'm overwriting the virtual function
void SendDataOnButtonClicked()
presenter->SetMode();
in presenter.cpp
void Screen1Presenter::SetMode()
model->SendEvent();
In Model.cpp
void Model::SendEvent()
Send data to backend.
Is this the correct way of sending data to backend when button is clicked ?
Right now I'm stuck at view.cpp.
I dont know how to call presenter  from view.
Codes that I tried.
Method 1:
Screen1ViewBase::presenter->SetMode();
Method 2:
Method 2:
Both these codes are throwing compiler errors.
Can somebody please help and let me know the right way of accessing the function in presenter?
JTP1Best answer
Graduate II
Jul 5, 2023 11:41 AM UTC
Hello. Method 2 is correct. There must some simple problem at hpp file maybe ... This 'void SendDataOnButtonClicked()' must be of course 'void Screen1View::SendDataOnButtonClicked()'.
What is the exact error ?
Here you can get simple example of MVP communication in both directions:
https://community.st.com/t5/stm32-mcu-products/toggle-button-off-after-a-specific-interval/m-p/569065#M217071
JTP1Best answer
Graduate II
KNara.2
KNara.2Author
Jul 5, 2023 11:53 AM UTC
Thank you so much @JTP1 .
Your solution helped.
