Nov 6, 2025 1:49 PM UTC
Color Eyedropper tool for flexButton cannot be toggled off when selecting another window
Hello!
I'm working with the flexButton tool and wanted to change the color via eye-dropper. But once I turned on that option, I was unable to turn it off, I can't disable the color picker and it continously changes the color even after deselecting.
Isolating the cause a bit I realized it only happens when I move my cursor off screen into another window and click, operating the tool normally (staying within touchGFX window) correctly turns off the tool after selecting.
Just a bug I noticed,
Thank you
Dec 4, 2025 1:13 PM UTC
Hello @noahl.
However, I have not been able to reproduce it. I followed this procedure:
  1. Create a new simulator project in TouchGFX Designer.
  2. Insert a Flex button.
  3. Navigate to Box With Border and select the Eyedropper for the released background color.
  4. Click in another window (I have also tried clicking another window on a different screen).
  5. When I click, the properties pop-up immediately closes, and the color is no longer changed.
Could you share the procedure you followed if it deviates from the one described above?
I used TouchGFX 4.26.0. Which version of TouchGFX did you experience the issue in?
Best regards,
Johan
