Epamuk
Oct 28, 2019 11:49 AM UTC
Code diferences between IAR and Touchgfx
Hello, I have a touchgfx project. When I compile project with touchgfx IDE (with Run Target button) It works properly. After that I open IAR IDE, compile and flash to my board but it doesnt work properly. When I debug software, I see there is a hard fault handler.
Is there any difference Touchgfx and IAR compiling process ?
How can I make it same ?
Ozone
Principal
Oct 28, 2019 12:23 PM UTC
Different compilers and different project settings produce different results, for sure.
I would start comparing stack sizes and optimization settings of both projects.
Epamuk
EpamukAuthor
Oct 28, 2019 12:42 PM UTC
hello
Where can I find touchgfx stack and optimization settings ? I couldnt find any data about stack and optimization in make file.
Where should I look for these settings ?
Ozone
Principal
Oct 28, 2019 1:25 PM UTC
You wrote: When I compile project with touchgfx IDE (with Run Target button) ...
I suppose some gcc-based toolchain. Check the IDE's help/tutorials.
I don't work with touchgfx.
Or, you could debug the IAR-WB built solution, and check what fails, and where.
Martin KJELDSEN
Principal III
Nov 4, 2019 12:04 PM UTC
TouchGFX "Run target" button uses makefiles to compile with arm-gcc. Can you tell me more about where this hardfault occurs? Which version of TouchGFX?
/Martin
