kjtl
Sep 27, 2019 8:57 AM UTC
Classes/functions to change the button graphics?
I'm trying to change the button bitmap from "button_pressed.png" to "button.png", after an interrupt event (without touching the display) . Could anyone shed some light on where I can swap the graphics? I'm a CPP novice, so the more information you can provide the better.
many thanks,
K
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Sep 27, 2019 1:39 PM UTC
Hi @kjtl​,
Use this function
 * @fn virtual void Button::setBitmaps(const Bitmap& bmpReleased, const Bitmap& bmpPressed);
 * @brief Sets the bitmaps used by this button.
 * Sets the bitmaps used by this button.
 * @param bmpReleased Bitmap to use when button is released.
 * @param bmpPressed Bitmap to use when button is pressed.
 virtual void setBitmaps(const Bitmap& bmpReleased, const Bitmap& bmpPressed);
So, essentially you could:
myButton.setBitmaps(Bitmap(BITMAP_NEW_BUTTON_RELEASED_ID, Bitmap(BITMAP_NEW_BUTTON_PRESSED));
myButton.invalidate();
Martin KJELDSEN
Principal III
Hi @kjtl​,
Use this function
kjtl
kjtlAuthor
Sep 30, 2019 7:22 AM UTC
That is just what I needed, thank you!
