Luk35
Jun 18, 2019 3:52 PM UTC
Circular Progress widget issue for negative angles.
in my project I have large circular gauge (circular progress widget). I am attaching link to google drive with project (simulator) below. Progress isn't properly drawn for negative angles. Am I missing something?
Manipulating with radius, line width and different cap styles changes behaviour.
https://drive.google.com/open?id=1TX2GJbksbZvzibpBIfqDNq9AqAVHYx0H
Edit:
Workaround: add 360 degrees to start and end angle - in my case from 240° to 480°
Martin KJELDSEN
Principal III
Jun 18, 2019 8:38 PM UTC
Hi @Luk35​,
I'll make a note to investigate this. You may have found something that could be improved, but for the time being, was intended.
Thanks!
/Martin
Luk35
Luk35Author
Jun 19, 2019 5:50 AM UTC
Thank you
