Chrom-ART Transparent rectangles / fills?
- 5 replies
- 1864 views
Hi, I've been working on a UI for past couple weeks,
I've successfully created functionality for drawing bitmaps (with or without alpha), anti-aliased fonts and solid rectangles / lines using Chrom-ART / DMA2D
I am however currently unsure how to do rectangle fills with transparency. I assumed that DMA2D_R2M would accept a ARGB color and layer configurations, however that was not the case.
Can someone explain in rough lines how I can fill a rectangle, that contains an alpha channel, over an existing drawn area?
http://preview.ibb.co/htzuzc/IMG_20180321_202jpg
My current bitmap/font character drawing function:
void
LCD
::DMA_DrawBitmap
(void
*pSrc,
void
*pDst,
uint32_t
xSize,
uint32_t
ySize,
uint32_t
ColorMode,
uint32_t
inputAlpha,
uint32_t
inputOffset) {hDma2dHandler
.Init
.Mode
=DMA2D_M2M_BLEND
hDma2dHandler
.Init
.ColorMode
=hLtdcHandler
.LayerCfg
[0
].PixelFormat
hDma2dHandler
.Init
.OutputOffset
=SCREEN_WIDTH
- xSize;
hDma2dHandler
.LayerCfg
[0
].AlphaMode
=DMA2D_NO_MODIF_ALPHA
hDma2dHandler
.LayerCfg
[0
].InputColorMode
=hLtdcHandler
.LayerCfg
[0
].PixelFormat
hDma2dHandler
.LayerCfg
[0
].InputAlpha
=0
hDma2dHandler
.LayerCfg
[0
].InputOffset
=SCREEN_WIDTH
- xSize;
/* Foreground Configuration */
hDma2dHandler
.LayerCfg
[1
].AlphaMode
hDma2dHandler
.LayerCfg
[1
].InputAlpha
= inputAlpha;
hDma2dHandler
.LayerCfg
[1
].InputColorMode
= ColorMode;
hDma2dHandler
.LayerCfg
[1
].InputOffset
= inputOffset;
hDma2dHandler
.Instance
=DMA2D
/* DMA2D Initialization */
if
(HAL_DMA2D_Init(&hDma2dHandler
) ==HAL_OK
) {if
(HAL_DMA2D_ConfigLayer(&hDma2dHandler
0
) ==HAL_OK
&& HAL_DMA2D_ConfigLayer(&hDma2dHandler
1
) ==HAL_OK
) {if
(HAL_DMA2D_BlendingStart(&hDma2dHandler
(uint32_t
) pSrc,
(uint32_t
) pDst,
(uint32_t
) pDst,
xSize,
ySize) ==HAL_OK
) { HAL_DMA2D_PollForTransfer(&hDma2dHandler
500
} } } }And rectangle fill function:
void
LCD
::DMA_FillRect
(void
*pSrc,
void
*pDst,
uint32_t
xSize,
uint32_t
ySize,
uint32_t
ColorMode) {/* Configure the DMA2D Mode, Color Mode and output offset */
hDma2dHandler
.Init
.Mode
=DMA2D_M2M_PFC
hDma2dHandler
.Init
.ColorMode
=hLtdcHandler
.LayerCfg
[0
].PixelFormat
hDma2dHandler
.Init
.OutputOffset
=SCREEN_WIDTH
- xSize;
hDma2dHandler
.LayerCfg
[1
].AlphaMode
hDma2dHandler
.LayerCfg
[1
].InputAlpha
=0xFF
hDma2dHandler
.LayerCfg
[1
].InputColorMode
= ColorMode;
hDma2dHandler
.LayerCfg
[1
].InputOffset
=0
hDma2dHandler
.Instance
=DMA2D
if
) ==HAL_OK
) {if
1
) ==HAL_OK
) {if
(HAL_DMA2D_Start(&hDma2dHandler
(uint32_t
) pSrc,
(uint32_t
) pDst,
xSize,
ySize) ==HAL_OK
500
} } } } graphics lcd ui chrom-art dma2d
