AndreaC
May 10, 2024 11:12 AM UTC
Changing text at runtime in custom container - Language issues
Description
I have created a custom container to have the same stuff displayed at top of the screen, whatever the active screen is.
In this custom container there's a text area tVersFw (with a wildcard and a wildcard buffer) which has to show a const string. I can't precompile the string in Designer beacuse the strings changes with firmware version (chosen at compile time by setting a preprocessor macro).
So, in the initialize() call of the custom container I added this code:
Unicode::strncpy(tVersFwBuffer, FW_VER_STRING, TVERSFW_SIZE);
tVersFw.invalidate();
where FW_VER_STRING is like "ABC123".
Issue
When I change GUI language, at runtime, one of the two languages makes the textarea show weird things.
It's systematic: when I select one language, "ABC123" is correctly displayed whikle when I choose the other I see something like "New TextABC123".
What am I doing wrong?
Thank you in advance,
Andrea
JTP1Best answer
Graduate II
May 10, 2024 11:33 AM UTC
Hello
At Tgfx designer, open 'texts' and check all autogenerated items. There is probably some 'New Text <value>' items in language column which is not working. Remove 'New Text' and leave <value>, it represents the wildcard buffer content. By default, this New Text is added to all languages.
Hope this helps.
Br JTP
JTP1Best answer
Graduate II
Hello
Hope this helps.
Br JTP
AndreaC
AndreaCAuthor
May 10, 2024 1:47 PM UTC
That's it!
Thank you very much,
Andrea
