Damiano
Change the name of the project in STM32CUBEIDE
it is possible to change the name of the project in STM32CUBEIDE?
The name is set by TouchGFX designer software by default.
When i tried to rename in STM32CUBEIDE i got an error.
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
April 8, 2020
Edit the name in the .project file. By default, the name is the root path of the application, but can be changed.
<?xml version="1.0" encoding="UTF-8"?>
<projectDescription>
	<name>new_name</name>
	<comment/>
	<projects>
	</projects>
Martin KJELDSEN
Principal III
April 8, 2020
	<comment/>
	<projects>
	</projects>
Damiano
DamianoAuthor
Thanks, it works :thumbs_up:
Martin KJELDSEN
Principal III
April 8, 2020
Great! :)
PJR42
That looked like the perfect solution ... until I tried it and nothing happened :sad_but_relieved_face:
Using 1.5.1. Am I missing something?
PJR42
Just figured out how to do it but couldn't delete my post.
You have to do it before importing the project and change the folder name as well.
