LSobo.1
Change Painter with Animation
Hello community,
i want to know if there is a easy way to change the Painter for a Shape (Circle) with an Fade Animation.
I can programmatically change the Color. Now i want to Fade the Color Change.
The alternative idea is to put a second Circle on top and dont change the color, but fade the alpha of the second circle on top of it.
Greetings
Alexandre RENOUX
August 21, 2020
You will find enclosed a small example where the alpha of the circle is changed (blue button = fade out, black button = fade in)
Hope this will help. If not, could you elaborate what you are trying to do ?
/Alexandre
