NHo.1
Can't set status of Scroll List when scrolls
Hi ST,
I have 1 problem when uses scrollList (or use scrollable + Listl ayout). I use a button to set visible scroll List to true. When not scroll, it works ok. But when i scroll, it can disable scroll List. Please tell me why?
Martin KJELDSEN
Principal III
June 11, 2020
Can you rephrase? Your issue isn't completely clear to me.
/Martin
NHo.1
NHo.1Author
I designs 1 button and 1 scrollList. I codes for button to setVisible scroll List (true or false). If i doesn't scroll, its ok. But if i scrolls this list, it cant setVisible when i press button. Why?
Alexandre RENOUX
June 16, 2020
Can you tell us exactly the steps in the right order you do to create your issue so that we can try reproducing it ? Otherwise, you can also enclose your TouchGFX project here. Please only send the gui/ folder, assets/ folder as well .touchgfx file so that it does not become a large size archive.
/Alexandre
