CHech.1
Can't compile in CubeIDE after deleting image in designer
I've come across what seems to be a Designer bug which I don't know how to solve or how to avoid it in the future.
I added an animated image to my project that consists of a few images. Afterwards I deleted the animated image and proceeded to remove the images the Designer's images screen.
Then, to my surprise, when I tried to compile through the CubeIDE I received the following error message:
make: *** No rule to make target 'C:/TouchGFXProjects/FirstApplication/TouchGFX/generated/images/src/image_FullPallete.cpp', needed by 'Application/User/generated/image_FullPallete.o'. Stop.
If I re-add the images, it works fine. If I try to delete them again, the same thing happens.
I don't want these images and I don't know how to get rid of them.
Thanks in advance!
Romain DIELEMAN
Romain DIELEMANBest answer
As Alexandre said this issue was expected to be fixed. The workaround otherwise would be to manually delete the "Debug" folder in the Tree View of your project in STM32CubeIDE.
/Romain
Alexandre RENOUX
August 30, 2021
Hello CHech.1,
What version of TouchGFX are you using ?
This bug should not appear with the latest version (4.17).
/Alexandre
CHech.1
CHech.1Author
Hi, i'm using 4.17
Romain DIELEMAN
/Romain
CHech.1
CHech.1Author
Thank you!
