AndyJT
Nov 7, 2018 11:47 AM UTC
Can DMA2D do a repeat buffer copy/fill from image ?
I have DMA2D (ChromArt) working fine for drawing images from memory to display buffer.
However, to save on image storage, I would like to create single pixel image "strips" which I can repeat a number of times in X or Y.
eg, for drawing a top border using a 1px wide by 20px high source image and outputting to the display buffer,say, 200 times across the screen.
I can't find any examples of this online.
Many thanks,
waclawek.jan
Nov 7, 2018 9:34 PM UTC
There no such feature in the hardware.
You can emulate it in software by performing the transfer of 1x20 strip 200 times; but probably it would be more efficient to draw 20 single-color 200x1 lines using the register-to-memory mode.
The transferring the 1x20 strip 200 times should be somewhat optimizable by halving and copying the already drawn piece.
AndyJT
AndyJTAuthor
Nov 7, 2018 9:50 PM UTC
Hi, thanks for letting me know for sure that it's not possible... Maybe something to be added to the hardware in the future... ?
I've already implemented horizontal copying using register to memory mode. Just working on a bug which is corrupting memory in the vertical version of the routine which must be related to offset(stride) setup being incorrect.
Thanks again!
