ananya
Oct 31, 2019 1:12 PM UTC
Calculating the memory requirements for screens
I want to calculate RAM requirement for one screen with some widgets and images.How can this be done.
Martin KJELDSEN
Martin KJELDSENBest answer
Principal III
Nov 4, 2019 9:39 AM UTC
Hi @ananya​,
Here's a way of calculating the size of both worst case View (including widgets) + Presenter or just the size for any screen you want. Then you have some memory for OS / Heap potentially.
int main(int argc, char** argv)
 // Print out size information
 printf("*** Memory usage: ***\r\n");
 printf("Largest view %lu\r\n", (long unsigned int) sizeof(FrontendHeap::MaxViewType));
 printf("Largest presenter %lu\r\n", (long unsigned int) sizeof(FrontendHeap::MaxPresenterType));
 printf("Datamodel %lu\r\n", (long unsigned int) sizeof(Model));
 printf("Total: %lu\r\n", (long unsigned int) sizeof(FrontendHeap));
 printf("*** Screens: ***\r\n");
 printf("MyView%lu\r\n", (long unsigned int) sizeof(MyView));
This code can be run in the simulator.cpp main() method.
/Martin
Martin KJELDSEN
Principal III
Hi @ananya​,
/Martin
ananya
ananyaAuthor
Nov 4, 2019 12:22 PM UTC
When I tried with the above in the main function, I got the following error in IAR.
Error[Pe070]: incomplete type is not allowed
ananya
ananyaAuthor
Jan 3, 2020 10:45 AM UTC
Hi @Martin KJELDSEN​ ,
When we want to calculate the RAM memory required for GUI,should we consider sum of all the screens' memory requirement?
How should it be calculated?
