Tuoman
Senior II
March 2, 2022
Bug report: TouchGFX Designer 4.18.1 does not regenerate text source files properly if assets\texts\ is changed directly.
TouchGFX does not recognize if changes have been made into this file externally.
Reproduce: make changes in assets\texts\texts.xml file -> regenerate with Designer -> texts/src/LanguageXXX.cpp source files are not regenerated properly.
Fix: make changes in Designer -> regenerate -> files are now regenerated properly.
Hopefully will be fixed. We edit assets/texts with scripts, and this workflow is not good.
Alexandre RENOUX
March 4, 2022
Hello Tuoman,
I cannot reproduce your issue.
Can you be more precise on how to reproduce the issue (with images to illustrate if possible) ?
The easier it is to understand the problem the faster it can be fixed :)
/Alexandre
