EKama.1
Nov 8, 2022 6:16 PM UTC
Backend Changing of framebuffer orientation
Hello. I saw a post about using a 180 orientation and did it, but as said, the performance was broken. Can i change the backend mounting of framebuffer? Where can i find where TouchGFX API is mounting framebuffer?
There is another way, like changing LTDC configuration for change the orientation between 0-90-180?
MM..1
Nov 8, 2022 6:30 PM UTC
Only display controller register config can change effectively
