Romain DIELEMAN
Aug 6, 2020 8:21 AM UTC
In the backend communication article in the documentation you can download projects on different boards using external buttons.
/Romain
TomJJJ
TomJJJAuthor
Aug 6, 2020 8:39 AM UTC
Thank you very much
MM..1
Aug 6, 2020 8:54 AM UTC
Add next key ...
if (HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_13) != GPIO_PIN_RESET)
key = 1;
return true;
if (HAL_GPIO_ReadPin(GPIOXX, GPIO_PIN_XX) != GPIO_PIN_RESET)
key = 2;
return true;
and to project
"PhysicalButtons": [
"Key": 1,
"Name": "BTN_USER"
"Key": 2,
"Name": "BTN_USERXX"
MM..1
Aug 6, 2020 9:02 AM UTC
Too you can aliasing gpio to keyboard keys ... and simply in model tick use
if (HAL_GPIO_ReadPin(SW_PWR_GPIO_Port, SW_PWR_Pin) == GPIO_PIN_RESET && filter == false )
  filter = true;
  static_cast<FrontendApplication*>(Application::getInstance())->handleKeyEvent(85);
85 is defined as key "U" in trigger designer...
TomJJJ
TomJJJAuthor
Aug 6, 2020 12:38 PM UTC
Thank you everyone.
i solved my issue
