AKrug
Feb 7, 2019 1:14 PM UTC
ApplicationTemplate for STM32F469I DiscoveryKit
ApplicationTemplate for STM32F469I DiscoveryKit create Keil project file for uVision v4 with wrong TargetOption. <Device>STM32F427ZI</Device>. Where i can get right ApplicationTemplate for STM32F469I DiscoveryKit ?
Thanks.
Martin KJELDSEN
Principal III
Feb 7, 2019 8:50 PM UTC
Hi @AKrug​,
You're right about the device type. What happens if you change to the proper device type? Are you able to program your board?
AKrug
AKrugAuthor
Feb 8, 2019 3:58 AM UTC
If I use only TouchGFX designer and Visual Studio there is no problem.
All Designers modes (Simulate, Run, Generate ) works without problem.
Visual Studio compile and run Simulator.
Problems begin if I try open Keil project file. It causes a storm of indignation from keil.
Replacing the device type does not give results.
As I understand it is necessary to make much more changes to the Keil project file.
Before, I didn’t use Keil so I asked where to get the working version of Application Template.
Can you send me the correct Keil project file for this ApplicationTemplate?
