Ezgi
Any changing in touchgfx libraries doesn't work on our device
While we were writing codes, everything is working perfectly in the simulator. When it was time to try it on our device, we had a problem about touchgfx and couldn't find it for a long time. However we realized that we added a variable to touchgfx's drawable class , which caused our device to stop working.
How could we fix this problem?
MM..1
?? how problem show code
Ezgi
EzgiAuthor
For example, we add "int AddRegister" to touchgfx::Drawable class, it works in simulator but doesn't work on device. A little changing in touchgfx classes, doesn't work on device.
MM..1
You still dont show how and where you add. show file name location and code
int AddRegister;
